Neo Neapolitan Sourdough Pizza Dough
Wow! Look how moist that is.
This pizza dough is a sourdough variation of Peter Reinhart’s Neo Neapolitan Pizza dough. The dough uses a small amount of commercial yeast and sourdough starter at 100% hydration. The result of this high hydration dough is a bubbly crisp pizza crust, which is easy to stretch out once you allow it to proof long enough.
1 teaspoon active dry yeast (or 3/4 teaspoon instant yeast)
1 oz/28g hot water, about 115F degrees.
–Add the yeast to the hot water in a small container and stir. Allow the yeast to proof for about 15-20 minutes.
Next, in a large proofing container or mixing bowl add together:
Look at this beautiful set up. You should see the mess when I (Brad) make my pizzas and take photos!
8 oz/226g of ripe and vigorous 100% hydration starter (ie, wet sponge starter as opposed to a firm starter)
13 oz/368g warm water, around 110F degrees
1 oz/28g olive or vegetable oil
.5 oz/14g brown sugar
.5 oz sea salt
–Mix all if the above ingredients by hand or mixer until incorporated and then add:
The yeast mixture
20 oz/567g bread flour
–Mix in the flour for about 1 to 3 minutes, or until the mixture forms a sticky dough ball. Allow the dough to proof in a lightly oiled, covered container for four hours. Fold the dough every half hour during the four hours for a total of six folds. It will firm up slightly and be less sticky.
–Once the dough is proofed, divide it into four or five pieces and form dough balls. Mist or brush the dough balls with oil, place them in a covered container, and refrigerate for 2 hours or overnight. Before using, allow the dough to warm up, uncovered, but well oiled, at room temperature for at least two hours. One-half-hour before baking, stretch or roll dough out and allow it to set for a while until baking time. (I stretch my dough and place it on parchment paper.)
Looks great!
–Then cover the dough with more oil (preferably olive oil), spread on your sauce and toppings and bake (baking time varies) in your very hottest oven. (Start with your oven rack and stone on the very bottom shelf preheat for at least an hour. Every oven is different so, if the pizzas bake too dark on the underside, move the stone up a shelf or two till you achieve an evenly baked pizza).
Note: The pizzas in the photos were made by Alexandra Jean and Teresa Greenway. For more information on baking with sourdough, my website is: www.northwestsourdough.com
Recent Articles by Teresa Greenway
Add Comment
Hi Kenny, I stretch the proofed dough using wet hands then place it onto parchment paper which makes it easy to slide onto the stone.
Don’t allow the dough to become too warm during final proof just before stretching or it will be too sticky and hard to handle.
Allow the cold dough to warm up to room temperature and don’t proof it in a warm place.
If your room temperature is very warm, allow the dough to warm up for one hour instead of two before stretching it.
Also don’t play around with the proofed dough, hands off until you stretch it. It is very extensible if you leave it alone.
🙂 Thanks for the reply Teresa! I started working w/a sourdough starter w/yeast from Ischia but it died. This gives me another reason to begin another starter!
How do we make this starter? Since it is an essential ingredient, it’s source remains a mystery to me.
This looks great, and we are planning on trying it at a party we’re hosting in a couple weeks (along with our regular dough). My question is: has anyone tried this in a WFO? I’m worried that it would be too hot for this dough.
Hi Mac Daddy, this dough will perform well in a WFO. I baked with Peter’s original formula in a WFO and it was outstanding. A dough with sourdough as part of the formula is even better at withstanding high heat.
