Grill Smoked Yellowtail Pizza
This piece of Yellowtail defined moist!
Fresh piece of Yellowtail
Sea Salt
A little Pepper
Chopped Garlic
Olive Oil
Fresh Squeezed Lemon Juice
Fire
Smoke
Timing
Perfection is not easy and once achieved is no longer perfection because it seems there is always something better coming. That’s interesting to think about. Have you ever seen the most beautiful girl you thought you had ever seen in your life? How many times? Funny isn’t it.
I took this one off just in time. It finished cooking under foil as I prepared to make the pizza.
I didn’t have time to do this one on the Weber though. So, as a substitute I used my gas grill and accompanied it with a lot of wood chips in my smoke box. This baby was thick. I wasn’t timing it, but I was nervously watching it because I was going to take this piece of fish and use some of it on a pizza. I definitely didn’t want it to go past that critical moment, and I actually wanted to pull it off the grill before that moment to make sure it was moist.
I began to flake the flesh apart to place on the pizza. It’s perfectly done – almost just slightly under fully cooked.
I laid this thick, beautiful piece of fish down and closed the lid. I did some more prep for what seemed like moments. I was nervous about this thing for some reason. I felt an urge to get out and turn it. But, I waited. I cut up some tomatoes. “You should let it sit there. Wait for it,” I kept saying to myself. I looked at the tomatoes and decided how many I would slice before I went back to check. Finally! I opened the lid and turned the fish. It was looking good! So, I put the lid back down to keep the smoke rolling around.
After a few more minutes, I did my finger test and decided that this piece of fish was done. It was time to rest it on the plate, covered in foil, as it finished cooking.
Grilled Smoked Yellowtail Pizza with Fresh Cherry Tomatoes and Ricotta
A “Brew in Germania” Pizza Dough – or any favorite dough!
Olive Oil
Halved Cherry Tomatoes
Ricotta Cheese
Torn Basil
Lemon Garlic Aioli Sauce *See below
Prep:
The Yellowtail:
Grill it (see above) and set it aside. This can even be cooled when you put it on the pizza after the pizza has baked.
The Lemon Garlic Aioli:
I found an aioli recipe that looked good. There are tons of them online. Here is a link to the one I used from About.com Culinary Arts: *Link but you can use your favorite version Make this beforehand and it can sit in the fridge.
Grill set up with Pizza Steel on bottom, fire brick on the side, Forno Bravo Thick Pizza Stone on top and fire box in back.
Spread your dough
Drizzle with Olive Oil.
Place pinches of the ricotta cheese around the dough. Follow with enough tomatoes to make sure you balance their function as a sauce and topping. When you do bite into them, you get that explosion of flavor. *See photos and then feel free to ignore what I just wrote and add as many as you want! I try to place as many as I can cut side down, because they steam and really hold in the moisture in the oven and are extra juicy when you bite into them.
Add the torn up, or chopped basil leaves.
I have to wonder why I didn’t take the picture facing the fire?!
Into the pizza grill it went.
I had to pull this out quickly because the steel bottom was so hot, it would have burnt the bottom. So, the dough didn’t quite get the rise I was hoping for.
The warm yellowtail topped with the Lemon Garlic Aioli to finish this off.
Pull off flakes of the yellowtail and spread around the pizza. Drip the aioli on top. In a sense, this pizza is upside down. The sauce is on top!
Stop the presses! OMG! TPII!!! Owen! Get over here and try this. In fact, it was so good, I wanted to make another. The dough was a little too burnt on the bottom. So, I wanted to give it another shot. I started the next on the top deck, the FB Baking Stone, and then moved it down to the steel to finish. This helped the crust situation and confirmed that This Pizza Is Insane (TPII)!!! I hope you were wondering what the heck that meant. If not, I feel sorry for you, but I’m impressed at the same time.
My grill didn’t do this justice! The heat was out of whack, but the taste was all there. This one is a winner!
Enjoy…
{gallery}grilledyellowtailpizza{/gallery}
