Drunken Mesquite Dough
The set up…
I set out to just make the dough, and took some pictures of the set-up because it just seemed like a “cool” thing to do. Or, maybe it’s because I often take pictures and blog about what I do around the kitchen? You decide. Anyway, as this dough came together it turned out to be a wet one. So, I started taking some more pictures as I went along. Here at Pizza Quest we see a lot of comments and I also get a lot of personal questions about making dough, and one recurring question is how to handle a sticky wet dough? And this one was definitely sticky and not just tacky. I must have simply added too much beer.
Almost seems like a tragedy, but worth the results in my opinion.
I could tell this was going to be a fun one!
This dough is based on Peter’s Neo-Neopolitan Dough, which is a great home pizza dough! It’s truly the easiest, and I always get great results with it in my home oven. So, when I tweaked it for my original Mesquite Dough, Peter had suggested using about 10% Mesquite flour in my quest to create a desert-inspired pizza. That dough came out amazingly well and was a perfect platform for that particular pizza, which I blogged about awhile back. The mesquite flour gives the dough an earthy, nutty flavor, but it’s also very light and smooth tasting. The mesquite flour actually makes the whole dough a little more velvety, if that makes sense. So here’s the latest version, with me pushing the envelope as far as I could to see where it would take me.
For more information and fun here are the links to my original Mesquite Dough Pizzas.
The Hwy 15 Pizza: *Link
A Wandering Desert Road Pizza: *Link
Let’s just say this little fella just liked the counter. I distinctly heard it say HANG ON!!
Combine the dry ingredients in the mixing bowl first and mix with a spoon.
Add the olive oil and honey if using followed by the beer.
The only way I could stretch and fold this was with the wet dough scraper!
Here’s where my dough pictorial goes off the tracks! You can see that this initial dough is super sticky! It’s impossible to roll/fold this dough with my hands. I had to use an oiled dough scraper to get it off the counter and try to make it into a ball. You’ll also see in the photos that the ball was flat and just kept spreading out under it’s own weight. It didn’t sit up like a standard dough ball because it was so moist.
I had to add a little flour and continue patiently stretching – folding – and resting the dough.
This dough took about 4 rotations to get it to where I could stop and the dough still remained super supple, but now I could handle it (of course, if I had cut back on the water — or the beer — by about 1/4 cup I might not have had to make all these adjustments).
If you keep at it, adding a little flour doing the stretch and fold and rest you will eventually find common ground with your dough!
So, if decide to make this dough, you may want to cut back the liquid just a little and you won’t have quite the wet experience I had, but will still come out with an amazing tasting dough. The flavor is nutty and light and, I want to add, the Double Barrel Ale brought out a maltiness that was terrific.
*Additional Note:
Here’s one of the pizzas I made later using this dough. Delicious!
“Another Breakfast Pizza” recipe: *Link
