A Wandering Desert Road Pizza
Fresh Nopalea Grande
I continued to shop, but now I was on another mission — to do another version of my Hwy 15 Pizza that featured a sauce made from pickled cactus. Lets see, what other desert ingredients can I bring to this pizza party? I figured I would keep this in the same vein as the original Hwy 15, but add something to it here and there to see where this experiment might lead. I found some Queso Fresco, which is a light, fresh Mexican cheese that can substitute for goat or feta cheese as a lighter fresher cheese option. I thought this might work well, allowing the other ingredients to shine. I figured I would once again use the pickled cactus sauce as the base, but add some fresh jalapeños into the mix.
After wandering around, I figured I had enough new items to create something that started on Hwy 15, but maybe ended up out on a deserted dirt road that wandered across the Nevada desert.
Mesquite Pizza Dough
Pickled Cactus and Jalapeño Sauce
Queso Fresco
Fresh Cactus Leaf
Thin sliced Pancetta
Whole Sage Leaves – chopped, or torn
Fresh Jalapeños – sliced
PREP
Spread dough and add the pickled cactus/jalapeno sauce.
I chose a Fire-Roasted Western Honey Mesquite Flour. Peter suggested I start with my first batch at 10% mesquite to total flour. I used the basic Neo-Neopolitan Pizza dough and added in my mesquite. (Note: If you’ve read my blogging much, you’ll have heard a few comments by my son Owen, or other family members. Owen may have a knack or a finely tuned palate. I once was making a few pizzas with some Bianco DiNapoli Tomatoes, used straight, as the sauce to see how good they were. Owen said, “Dad, this is the best sauce you’ve ever made!” Well, all I did was open the can. Thanks Owen! He did it again with this Mesquite Dough. He said, “Dad, this is the best crust you’ve ever made!” He had no idea I made this with the mesquite flour. He just showed up for some testing of the finished product. Anyway, as Owen can vouch, it’s good!)
Here’s a link to The Mesquitery where I got the Fire-Roasted Western Honey Mesquite Flour: www.mesquiteflour.com
Neo-Neopolitan Dough Recipe: *Link
Pickled Cactus and Jalapeños Sauce:
This is really an elaborate variation of a basic herbed oil that you can use as a sauce, or topping on any pizza.
– Pickled Nopalitos (Cactus)
– Pickled Jalapeños
– Garlic
– Olive Oil
– Fresh Ground Pepper
Chop the cactus and jalapeños and some garlic to taste and place in a bowl.
Add olive oil and freshly ground pepper.
Measure and add ingredients to taste. The cactus is somewhat sweet with a nice tang from the pickling. The jalapeños add some heat and a little salt – because I am using my soy pickled jalapeños. Pull the solids from the sauce onto your pizza, being careful to manage how much oil you get on the pizza. You don’t want it to be too runny. Mix the ingredients and let sit to marinade for as long as you can for the flavors to come together.
Slice thick enough to hold up in the oven.
Fresh Cactus Leaf
To prepare your cactus leaf check out this simple video demonstration at RivenRock.com. *Link
It’s really simple. You use the scrubber side of a sponge to lightly remove the spines. Then you simply trim the edges and slice your cactus into the shape you want to use.
All the layers together – into the oven it goes…
Spread the dough
Add a scoop of the sauce and spread across the dough. Add more as desired, or place on top of the pizza before, or after cooking.
Break off chunks of the Queso Fresco to cover the pizza.
*Prior to assembling the pizza:
Lightly fry up the chopped sage leaves and sliced jalapeños until just tender. They will cook more in the oven. I used a little of the Pickled Cactus Sauce as the oil.
Add pancetta over the cheese.
Add your sliced fresh cactus
Top with some of the sautéed jalapeños and sage.
Into the oven it goes.
When it comes out of the oven, which slice you’ll eat, nobody knows! Delicious textures, flavors and a memorable celebration of the desert to say the least!
Layers! What struck me here was the layers of flavors/textures created using fresh cactus and pickled cactus. I am now a born again cactus fan! I have since made some of my favorite homemade salsa using chopped fresh cactus. It has a really fresh flavor. I sliced the cactus thick enough so that it retained it’s moisture. It was like the oasis of moisture on my pizza, just like the cactus is in the desert. The pickled cactus added a vinegary accent, while the fresh cactus gave a soft fresh juicy note as you bit into it.
I will definitely keep playing with this new ingredient while exploring my desert pizza experiment as well as on other foods I enjoy like: tacos, burgers, salsas, salads and maybe more?!
Enjoy!
{gallery}wanderingdesertroadpizza{/gallery}
