Pizza Ovens | (800) 407-5119 | Info@fornobravo.com
logo
store logo
start shopping button
Home
Order
Forno Bravo UK
Dealers
Photos
Recipes
cooking_banner
recipe button
ingredients button
techniques button
Steam in Your Brick Oven
Here is the two-part method for creating steam in your brick oven recommended by Jim Wills, our good friend at Mary G Artisan Breads, a wonderful wood-fired micro bakery in Ontario, Canada.
Fire your oven for at least one hour, bringing the dome and floor temperature to roughly 800ºF, and to where the entire dome has gone clear. Then after the ash has been raked out, leave the oven to moderate for an hour or so, about the time you take your slow rise doughs out of the refrigerator. Depending on the type of bread you are baking, let the oven temperature fall to between 450ºF-550ºF. Then, brush and mop the hearth with a damp, not wet, towel.
At this point, you can either put an old sheet pan loaded with damp rags into the oven, or give it a long spray with a basic garden sprayer. If your oven is hot, and you want a lot of steam, try doing both. When the breads go in, there should be visible steam in the chamber. Once the bread is loaded, give the oven another long spray, pointing the nozzle upwards, not at the breads. Again, there should be visible steam in the chamber.
Remember, without steam, the crust will not develop properly and caramel ization will be underdeveloped.
To retain the steam, it's important that the door seals the oven opening. If your door does not want to maintain a tight seal, try using a brick to keep it pushed tightly against the opening.
Simple, but effective.
Check out Jim's great bread in the attached photo. See the wonderful oven spring that results from his steam method.
Jim Wills at Mary G Bakery
Home | About Us | Our Suppliers | Dealers | Press and News | Contact Us | FAQ | Forno Bravo UK | Shop Forno Bravo
Residential Pizza Ovens | Commercial Pizza Ovens | Catering Pizza Ovens | Pizza Oven Accessories | Pizza Peels | Outdoor Fireplaces
Select | Justify | Order | Install | Manage | Make Pizza | Roast, Bake and Grill
Pompeii Brick Oven | Firenze Concept Oven | Links | Vera Pizza Napoletana | Pizza Oven Photos
Commercial Pizza Oven Selector | Outdoor Kitchen Design | Site Map | Forum
Forum Archive 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29
© 2006/7 Forno Bravo, LLC Italian Pizza Ovens
No part of this website or content thereof may be reproduced, distributed or transmitted in any form or by any means, nor may any part of this website be stored in a database or other electronic retrieval system, or any other website, without the prior written permission of Forno Bravo, LLC.
spacer spacer spacer
